I did, with everything attached I shorted the lead with the little screwdriver you see in the picture.I assume you short with balance lead’s connected? Without any load attached
Fantastic! It worked! Fixed in seconds. Thanks so much. I connected my meter to both terminals to monitor and used a small screwdriver to bridge the pins worked immediately.
How often do you have to re-wake it up? It’s not something my wife could do if I’m not about.Once every now and then I have to short out the B- and P-. I do it momentarily. A fraction of a second with a wire.
This has helped to "start" the BMS for me when nothing else will.
Hope this helps.
I have had to do it maybe once every time I use it. However when I use it is only when charging my cells currently. I have 3 bad cells currently so things are wildly different for me.How often do you have to re-wake it up? It’s not something my wife could do if I’m not about.
Use the search feature on the forum, besides pictures, I have also posted links to connectors and switch on Amazon. I suspect your wife could handle pushing a button.How often do you have to re-wake it up? It’s not something my wife could do if I’m not about.
What two pins are you talking about?It's not actually woke up, there are 2 pins in a socket for the Daly SOC monitor that you have to short together to get it to wake up. I have the same BMS and it did the exact same thing until I shorted the 2 pins with a test lead.
Which Daly BMS do you have?What two pins are you talking about?
Delete pleaseIt's not actually woke up, there are 2 pins in a socket for the Daly SOC monitor that you have to short together to get it to wake up. I have the same BMS and it did the exact same thing until I shorted the 2 pins with a test lead. I'll dig mine
Thanks. The lead and button are in their way. I’ll mout on the battery box so the wife can access easily.Which Daly BMS do you have?
12v "Smart" BMS:
24v "Smart" BMS lightboard:
For the 12v model, you can easily make a reset button:
Amazon.com: E-outstanding JST 2.0 PH 2-Pin Connector 5Pairs Micro JST-PH 2.0 Connector Male and Female Plugs Connectors with 20cm Cable Wires : Electronics
Amazon.com: E-outstanding JST 2.0 PH 2-Pin Connector 5Pairs Micro JST-PH 2.0 Connector Male and Female Plugs Connectors with 20cm Cable Wires : Electronicssmile.amazon.comWayinTop 18pcs Momentary Mini Push Button Switch Lockless 2 Pins 1A AC250V/3A AC125V SPST 6-7mm Automatic Reset Switch (Black/Red/Green/Yellow/Blue/White): Amazon.com: Industrial & Scientific
WayinTop 18pcs Momentary Mini Push Button Switch Lockless 2 Pins 1A AC250V/3A AC125V SPST 6-7mm Automatic Reset Switch (Black/Red/Green/Yellow/Blue/White): Amazon.com: Industrial & Scientificsmile.amazon.com
For the 24v model:
Amazon.com: LATTECH 8 Sets JST PH 2.0MM 8 Pin Female Single Connector with Flat Wires 200MM 1007 26AWG : Electronics
Buy LATTECH 8 Sets JST PH 2.0MM 8 Pin Female Single Connector with Flat Wires 200MM 1007 26AWG: Connectors & Adapters - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.comWayinTop 18pcs Momentary Mini Push Button Switch Lockless 2 Pins 1A AC250V/3A AC125V SPST 6-7mm Automatic Reset Switch (Black/Red/Green/Yellow/Blue/White): Amazon.com: Industrial & Scientific
You are welcome. LOLOLThanks. The lead and button are in their way. I’ll mout on the battery box so the wife can access easily.
Thanks a lot for this post. I could not wake my Daly Smart BMS after connecting it for the first time to the battery pack. Shorting B- and P- did not help. I thought I had fried the BMS. After shorting those two pins, now is my BMS woke24v "Smart" BMS lightboard:
Sorry, that's counting from the right, so 6 and 8 counting from the left.I have a Daly 8S 24V R32W-GA29.
I have not yet managed to start it. Tried with shorting B- and P-. And now I tried shorting the two pins (1 and 3). I assume that it is from the left you count. So first and third PIN from the left should be short?
I have a lightboard on the way from china but I can´t wait. I also tried with connecting the USB to UART cable to see if that could start things up. But NO. :-(
Thanks for clarifying.Sorry, that's counting from the right, so 6 and 8 counting from the left.
I gave some links to Amazon, so you can have a connector with wires in two days depending on where you live. You don't even need a switch, you can just short the bare wires.
My apologies, I had the connector flipped so I could use my meter on the contacts and didn't make that clear.
