Just tell me to shut up when you get tired of the questions. This application is on a home.
1. My batteries charge very quickly where my setup goes to float mode and stops charging, 24 volt system. Seems like I am wasting a lot of free potential energy. What can I do with it? I do not have anything hooked up on the Load Terminal. My solar controller will allow me to program a feed through the load terminal with voltage turn on after a certain point and or time activated circuit. Creative suggestions? Anything with a water heater?
2. Is there a low voltage alarm that can be wired to the batteries to trigger a light or beep, 24 volt system. Setup is in the garage so it beeps in there but want something in the house. Just thinking about night time to let me know before the batteries shuts off and kills the inverter.
3. Guessing someone has a model/item of a good low voltage auto disconnect for 24 volt setup for the batteries.
