sethile
- Dec 29, 2021
- 113
After searching and reading here, I find I'm apparently not the only one that finds the options for combiner boxes surprisingly limited, pricey, and a little confusing.
I'm looking for a combiner box (or a pair of them) for an Off Grid system based on the MPP LV6548 I have on backorder.
The LV6548 controller specs are: 120A Mppt at max 250Voc – 2 x ( 4kW MPPT Charge Controllers).
I've got 26 used 250W panels. Their specs:
37.6 Voc
30.3 VPmax
Current @ Pmax 8.27A
Max System 600V
Fuse ratting 15Aw
Configuring the panels in series pairs would seem to optimize the yield due to shading and orientation challenges for my installation, but it makes for a lot of strings to parallel . Maybe it's not worth it?
Plan A:
Input 1: 2S8P (spilt up in two arrays of 2S4P each, one on a south facing garage wall, and the other on an East facing roof. If my math is correct, this yields 4KW, 75.2Voc, 66.16A.
Input 2: 2S5P on the East facing roof, which I think yields 2.5KW, 75.2 Voc, and 41.35A.
Combining solutions:
2 of the 8-1 Watts247 boxes that Will reviewed would likely be great for this, but they're back ordered until March 15th. I'd really like to have things ready to go when my back ordered MPP LV6548 shows up. It supposedly ships February 22.
I'm trying to overcome the sticker shock on a pair of Midnight Solar Mnpv12s and 13- 20A breakers (closest to 15A I could find on Amazon?) for a total of $706.30. Or I can get the 15A breakers along with a pair of the Mnpv12s for $765.64 at Wind and Sun (Northern AZ, anyone dealt with them?). Their breakers are cheaper, but the boxes are more. Guess I could split it up.
Main questions:
1. Am I missing some obviously less expensive or any easier solutions? I had thought about branch connectors with in-line fuses, but that sounds like a mess of wires and potential failures. Worth considering?
2. Should I consider a different configuration with more panels in series and less parallel strings in spite of the shading and orientation challenges?
3. If I go with the Midnight solar set up, Is it a safe to go with 20A breakers instead of 15A?
I've been fiddling with the solar array layout in case that's relevant. The first is what's on the east facing roof, and the second is what's on the south facing wall, which I intend to mount at an adjustable angle. (sorry for the ghetto graphics):
37.6 Voc
30.3 VPmax
Max System 600V
Fuse ratting 15Aw
Plan A:
Main questions:
