HarryN
Solar Wizard
Again, who is installing PV facing the wrong direction? What is the right direction? How do you know? What modelling did you do to determine that? How do you know what the correct amount of storage is for a particular project? Did you evaluate the time based LMP pricing at that grid node? Did you do a life cycle cost analysis to establish the ratio of PV to storage? I can assure you that the project developers aren't stupid. They do all those things, and more, to configure their systems, because that's how they make their money.
I suspect that what you are thinking is the current approach was the approach 5 or 10 years ago when the duck curve was not nearly as deep as it is now, so midday energy production had much more value. No developer in his right mind would do that today, because they don't make any money by doing that.
With all due respect it's not the politicians that are oversimplifying, it's you. The politicians aren't telling the project developers which way to orient their PV arrays. They establish an electricity market that sends the right pricing signals and let the generators figure that out for themselves, as they should in a free market.
I have two test stands and run my off grid work shop from solar. So my experience is not identical to yours, but using your suggested configuration would require me to own a much larger battery pack and have many more panels than I use now to accomplish the same results.
I suggest that you attempt to model a vertical array with panels facing early morning and late afternoon and see what results you end up with. It certainly has less impact on projects that are intended for dual use agriculture, and the panels are largely self cleaning.
If you are getting push back, it is because your customers are not listening to what is acceptable / viable, vs just ruining the agricultural use of land.
