Here's a
link to the Signature Solar page (which came up first in my search). The Snap-n-Rack's page is
here.
I haven't used these mounts so this is just my opinion.
1. They do allow for some horizontal and vertical adjustment. As long as you install them right, you could later install a larger or smaller panel. The vertical adjustment would come in handy when the panel is installed on a section of the roof that is curved (front to back). I have this exact situation, so these mounts have really peaked my interest.
2. Installation with the Top Speed bracket
should be faster than with Z-brackets. But is it twice as fast?
3. Most Z-brackets use two fasteners per bracket. The Top Speed mount uses four. That's twice as many holes on the roof. I suppose you could use just two screws but that probably would reduce their wind rating.
4. I prefer nut and bolt attachment at the solar panel for a mobile environment. Given the Rolling Earthquake nature of an RV, I want a solid attachment to the solar panel.
5. Due to obstructions, I had to raise the height of the panels along the center line of my roof. The Top Speed mounts and Z-brackets wouldn't work in that situation. Strut was the solution there.
6. My panels hang over the edge of the roof by a small amount. The Top Speed mounts and Z-brackets wouldn't work in that situation. Again, strut was the solution there.
7. It works with panels with frames 32 to 40mm thick. I was looking at a Qcell panel that was only 30mm thick. It could be argued that nobody in their right mind would use thin framed panels in a mobile environment so this probably isn't a concern.
8. The wind rating is definitely a concern. The more brackets you use the more secure the panel is. The wind rating on their website is "90-180 mph Wind Loads and 0-90 psf Snow Loads". I don't know how that compares to a Z-bracket or strut. I was planning to use six mounting brackets with my panels so six of these Top Speed mounts sound about right.
9. The Top Speed mount may be less expensive than using strut. Z-brackets would be much less expensive than the Top Speed mounts.
10. The Top speed mount is going to weigh less than strut (that shit gets HEAVY unless you use aluminum). Z-brackets weigh almost nothing.
I'm gearing up for installing a couple more panels on my roof in an area with fewer obstructions and I'm also using smaller panels that fit better. The plan is to use off-the-shelf Z-brackets or my own DIY brackets.
Perhaps
@SignatureSolarJess can offer some insight into if their customers have used these mounts in a mobile environment.
