Mount/Bracket for flat roof with no Drilling into roof?
JohnnyDangerDude
USA
How do I mount to a flat roof without drilling into the roof?
Is there like some kind of ebay/Amazon product that I can buy for this ?
Something that perhaps can use weight to keep the panels in place.
Also what is the normal angles these are suppose to be. I am in the 33156 zip code(South Florida)
Thanks.
Look for ballast roof mounts, though you’ll want to ensure your roof can handle the weight. Given your other thread I’m not sure of the construction quality of the house, and you don’t want the ballast buckets to end up in your kitchen.
Thanks. All American Home Improvement
Does anyone know if a non-penetrating roof mount is referenced in the electrical code and where I can find it?
I’ve also seen glued mounts, but of course those are only as good as the surface immediately under the glue, so no way would I trust them.
You should probably talk to your AHJ and see what they’ll approve.
