Mounting/ergonomic question for instal
Nan_wpg
I’m ordering pre made cables from battery cables usa. connecting A server rack battery to a Victron multipluss.
battery is 18” tall (I’m standing it up against wall), Victron is 26” tall (let’s call it 2 feet). I’m also connecting a t class fuse, and smart shunt about 12” from the battery. (Closer is better but 2/0 is stiff so I’m allowing a bit more leeway)
just wondering how long of cable to order to go from the fuse / shunt to the inverter…… so I guess I’m asking ergonomically how high are you guys typically mounting these inverter chargers?
not too low, not too high, im thinking the middle of the multipluss should be about eye level-ish? Sound about right?
Generally, you should stay below 6'-6".
Go with what will be comfortable for you.
You are the one who will be looking at and making adjustments.
