JoeyJibJab
Hi guys, Ive begun mounting my solar panels to my car port roof. I'm a little unsure about grounding the system. I'm fastening the panels with L brackets, secured directly onto the metal roofing. My question is, isn't that basically grounding my system to the metal roof and thus the steel supports holding the roof up?
Should I be insuring that the panels aren't making direct contact to the metal roof and then grounding the system with grounding cable? Hope that makes sense. Thanks
I've attached some photos to make it more clear
