SolarSam2021
- Dec 31, 2021
- 6
I am looking for a way to mount solar panels in a 2nd floor apartment window. They will only be there for emergencies, and not installed all the time.
Thank you for your help!
Sam
- Multiple posters have warned against solar through glass, and I can confirm that the power is reduced to the point where you barely get anything. So the panels will have to be outside of the window
- There is no ledge I can put the panels on, so they will need to be held up somehow
- I have 3 100W panels which are about 15 lbs each. I need to connect them in series to meet the minimum voltage for the charge controller
Sam
