I have a rolled roof and 4 small 100 watt solar panels. I was thinking I would mount the solar panels onto the roof studs using the mounting brackets that came with my solar panels and fill the drill holes with wet patch before tightening down screws. Then a similar plan with the cable entry box. I might press 2x4 between studs if I need something more to tighten down on to.
But in a lot of the videos I see, they are using some type of rail system to mount solar panels. Is this something I should mount on instead. Are there advantages to them.
Please keep in mind that I have next to no construction or electrical experience. Ron Swanson would laugh at me. So anything to add would be helpful.
