leesmith2097
- Nov 14, 2021
- 35
Hi guys
Hi
I want to use my solar with a tie grid inverter and if possible run it with my current off grid, but dont think thats possible.
I have been doing my research and using my 150w and 320w solar panels in a series I will have a total maximum circuit voltage of 62.9v.
The spec of the 150w panel spec is
The 320w panel is
Watt: 320Wp
Max Snow Load 5400Pa , 112lb/ft2
Max Voltage Vmp 32.76V
Cell Size 156x156mm
Nominal Current Imp 9.77A
Number of cells 60
Open Circuit Volts 40.60V
Frame Anodised Aluminium Frame.
Short Circuit Amps 10.23A
Diode Junction Box IP67
Module Efficiency 19.19%
Length 1664mm
Max System Volts 1000VDC
Width 1002mm
Power Tolerance 0 , + 3Watt
Height 35mm,
Weight: 18kg
Max Series Fuse 15A
Warranty: 25 years
Operating Temp: -40 oC to 85oC
Module Cables 4mm2 with MC4
I currently have the 2 panels separately going in to a off grid inverter which is a 1.2KW 12v Conversol brand, it would have been nice to link the panels up in series to the off grid inverter if it can handle it and to a grid tie so i get best of both worlds.
The inverter which I have seen is below, but I think its may be over kill for what I need? i need to consider DC isolation and ive already got a 240v electric junction box.
whats difference between such as one of these?
any advice and recommendations is appreciated.
Thanks
Lee
Lee
Hi
The 320w panel is
Watt: 320Wp
Cell Size 156x156mm
Number of cells 60
Length 1664mm
Width 1002mm
Height 35mm,
Weight: 18kg
Max Series Fuse 15A
Warranty: 25 years
SOLIS 1000−4G 1KW 1 MPPT
The intelligent MPPT controller optimise the performance of the panels by generating electricity from astart up voltage of 60V. With the development of the Solis 1000 has made it possible for smaller solar installations, consisting of just a few panels, to contribute to a durable energy...
voltaconsolar.com
Thanks
Lee
Lee
