Sverige
A Brit in Sweden
I’d like to make use of my off grid inverter (220-240V single phase AC) to power some circuits in my house on a switchable basis, ie. only switched on once in a while when I have enough accumulated solar power in battery. The rest of the time these circuits will run mains from the standard domestic supply.
So I understand I need to move the circuits to a separate sub panel and switch the supply to that panel between utility mains and inverter output in a safe way (break before make). Ideally I would do this with a simple mechanical switch, as I don’t need remote control or automatic failover switching and then there is no power drain from relays being held closed, etc. I didn’t yet find a good mechanical switchover option, but see a number of inexpensive automatic switchers such as this one.
What should I be thinking of before undertaking a change like this, and do you think the product in the link can be trusted? Have added some pics taken from an eBay listing for the same Htronic / solartronics MPC1000
