I am in the process of designing a system for a new home that we will hopefully be building. Am I correct that I would be able to purchase 2 of these kits and an additional 20 panels to end up with a 14.8kw array? What size lithium battery bank should I consider? The majority of the electrical loads in the home will be 120v. Water heater will be a power vented propane. Dryer will also be propane. There may be a propane furnace. No a/c. Primary heat will be wood. Well is 160’ deep no pump yet but very well could be only 240v load. https://watts247.com/product/lv6548-6-5kw-3-7kw-bundle/
