I have this inverter on a 48v battery and producing 240 volts A/C.
Its wired up normally as is the 240v A/c output but I ran the output through a RCD first then to the outlet plug . All the earths are connected together BUT I have not yet connected them to the main earth ground peg .
Before doing so I turned the inverter on and measured the A/C voltage from the unconnected earth to earth proper and found it had a 48v A/c potential.
Is this correct? Is it how it should show at this time ?
Or is that telling me something is amiss.?
