ArthurEld
Solar Wizard
Both of those disconnects are for 32A max. I think they might be for solar panels not batteries.
The conversation was about the battery on/off switch. JoeHam mentioned that the one DanF has is only good for 48V.Yup. PV disconnect. I thought thats what you meant. I will be using the AIMS disconnect attached to the house, and then 20A DC breakers on each PV input on the inside before the LV6548.
LtDan put up a link for a PV disconnect switch. I thought thats what he was looking for. As for 60V DC battery disconnect, Gigavac is an alternative, but they are expensive. I may try out one of those supposed 60V 350A $14 dollar chinese jobs on Amazon.The conversation was about the battery on/off switch. JoeHam mentioned that the one DanF has is only good for 48V.
So, I was hoping someone would post what they are using for a battery on/off switch that can handle up to 60V.
I have 5 batteries and I would like to be able to turn any one off while the rest are still able to function.
Hey DanF, sorry about my intrusion into your thread. I now understand that was a "dick move". That being said, your install gives me a woody! Are you using fireproof back board? Or is it Plywood?Batteries are balanced. Starting A.C. terminations in the J.B. Finishing some terminations on the A.C. side and beginning to build the battery box and start work on the D.C. side. Terminations from the Main panel to the J.B. still need done as well as installing the 60a breaker.
That sounds good. cinergi went that route too.I like to use breakers. Here is a higher volt/amp example:
Midnite Solar MNEPV 150 Volts 100 Amps DC Solar Array Breaker
Midnite Solar MNEPV 150 Volts 100 Amps DC Solar Array Breakerwww.solar-electric.com
This is a gorgeous build. Extremely elegant.Beginning the DC side install. Made some bus bars, and began mounting and terminating inside the battery box. Ran out of 4/0 lugs, so I'll work on a good spot for the battery equalizer location until I get some more lugs.
I have been setting up the inverters and running tests with charging and dis-charging the system the past couple of days and this will continue for a bit. I will be installing some wood to blank off the rest of the exposed wiring, then I will focus on the solar panel part of the install to finalize the build. To answer your question, I am weeks away from that part and have not decided.@DanF what will you be using as a breaker/disconnect between your inverters and the PV Panels?
Plywood back board but so far during my tests I have had no temps on the back side of the inverters over 80 degrees so I'm good with that.Hey DanF, sorry about my intrusion into your thread. I now understand that was a "dick move". That being said, your install gives me a woody! Are you using fireproof back board? Or is it Plywood?
Yours is one of the cleanest cabling i have ever seen. I work in Data Centers, so that is saying a lot. Nice job!
Any updates on your progress? How are the 6548's working out under load?
What charge, high, low settings are you using on the BMS and Inverter?
I am still waiting on my Lishen cells, and my setup is kinda based on yours, so I have lots of questions.
Thanks for the update! Cool that your an AWS guy! That explains a lot in your design expertise. By the way, I just received an update from Blue Sea, and they confirmed that their switches should not be used in 48V environments. I think JoeHam gets a beer on us, as he may have saved us from a fire!Plywood back board but so far during my tests I have had no temps on the back side of the inverters over 80 degrees so I'm good with that.
Thanks for the kind words. I actually worked at the Amazon Data centers in our area doing temperature control work on the build outs for the past 4 years myself.
The 6548's are flawless so far. Lots of settings to go through. The BMS is its own entity. JK 2a active balancer. I have my batteries set to disconnect at 48v from the inverters on the low side then they transfer back to grid. Charging is set to 20amps but it ends up being 40 with two inverters installed as split phase. The charging disconnects at 56v on the high side. (So 3.0v-3.5v/Cell).
Yeah, there is a very recent post by that Austrailian German guy over at off grid garage who is having issues with his battery cuttoff breaker that looks just like that T Tocas one.Your system, your choice but I wouldn’t use the T Tocas craptastic ones. Plenty of discussion on the forum :
Search results for query: Tocas
diysolarforum.com
