Just purchased my MPP LV6548 and have my LiFePO4 battery cells coming as well.
Now, solar panels.
Does anyone have any thoughts on these cells and if they will work with the MPP LV6548? Appreciate any thoughts or help you can provide.
I am looking at getting as close to 8000W as possible with the fewest panels as possible while staying within the MPP requirements.
The LV6548 example is listed above and the data from the manual is below:
USER’S MANUAL
Now, solar panels.
Reference | Mission | Prisim | Trina | |
Example | ||||
330Wp | 385 | 385 | 400 | |
VMP | 33.7Vdc | 40.84 | 40.8 | 41.1 |
Imp | 9.79A | 9.426 | 9.43 | 9.74 |
Voc | 39.61 | 48.53 | 48.5 | 45.4 |
Isc | 10.4A | 9.993 | 9.99 | 10.18 |
Cells | 60 | 72 | 72 | 72 |
Efficiency | % | |||
Cost | $ 155.00 | $ 155.00 | $ 200.00 |
USER’S MANUAL
INVERTER MODEL | LV 6548 |
Max. PV Array Power | 8000W |
Max. PV Array Open Circuit Voltage | 250Vdc |
PV Array MPPT Voltage Range | 90Vdc~230Vdc |
Start-up Voltage (Voc) | 80Vdc |
SOLAR INPUT 1 | SOLAR INPUT 2 | Q'ty of panels | Total Input Power |
Min in series: 3pcs, per input Max. in series:6pcs, per input | |||
3pcs in series | x | 3pcs | 990W |
x | 3pcs in series | 3pcs | 990W |
6pcs in series | x | 6pcs | 1980W |
x | 6pcs in series | 6pcs | 1980W |
6pcs in series | 6pcs in series | 12pcs | 3960W |
6pcs in series, 2 strings | x | 12pcs | 3960W |
x | 6pcs in series, 2 strings | 12pcs | 3960W |
6pcs in series, 2 strings | 6pcs in series, 2 strings | 24pcs | 7920W |
