Sanwizard
Solar Wizard
- Feb 2, 2021
- 2,711
After many hours of trying to troubleshoot why my Raspberry Pi was not communicating with my Inverters, I broke down and paid the $55 dollars and bought the Solar-assistant.IO software. Instant satisfaction. I also purchased the Victron shunt ve bus to usb cable they sell, and now I can monitor SOC and just about all the parameters on my Inverters. The logging is awesome!I totally agree with the BMS comment and NO fan. Point of failure to me as well.
The 500A smart shunt is fantastic to use in cooperation with the JK balancer for monitoring and yes I use it for SOC and other important data. With my charge/discharge parameters on the MPP's (50v-56v) I get about 250ah out of 272 rated and I'm happy with that! The smart shunt will tell you that data. The only thing that sucks about it is the bluetooth in my opinion. The range is horrible compared to the range with the JK balancer bluetooth.
I am also working on some upgrades (as Sanwizard is) with the raspberry pi to graph everything and it won't matter then. Not so sure I can accomplish the programming lol, but we'll see.
Good luck with your build! It's pretty cool to see what these Lifepo4 batteries can do! You are in the right place with this forum, plenty of help here with very knowledgeable people.
I highly recommend that solution. You can even buy a preloaded Raspberry Pi from them! Plug and play.
I am using the JDB/Heltec 200amp/2amp active balance smart BMS with bluetooth. I agree with Dan that the bluetooth sucks, but they work great with my Prismatic cells. My cell delta stays at a consistent .008mv.
I am about to add an additional 14KW of battery to the system, so the SOC becomes more important across banks. I am hoping to find a way to have the Victron shunt communicate SOC status to the Inverters, but have not found a solution yet. The solar assistant software shows status, but I want the inverters to also be able to get that info.
I believe I can buy a Seplos BMS for each bank, which can emulate Pylontech, but I already have $800 worth of Heltec BMS's.
Direct comms between the Inverters and my BMS would be perfect. I asked Ian at Watts247 to check on futures on that front.
