MPP LVX6048: Are the Neutral and Ground bonded inside when using only battery input?
If this is true when back feeding a main panel there will be a ground loop when between the main panel (N-G bonded) and the LVX6048 ( N-G bonded). Can it be confirmed that the LVX6048 operation is identical to the LV6048 in respect to N-G bonding operation?
If so, does the LVX6048 also have a screw that can be removed to remove the internal N-G bond when in battery input only mode?
