It's a PIP-LV-MK 3KW 48volt.
Been running just fine for about 6 months, now for no apparent reason it can't 'see' the solar input.
Did the obvious and checked the panel output, 90 volts and the current was quickly rising as the sun came up, but I had to stop at 10A which is the limit of my multi meter.
So here's the weird bit. Reading at the solar panel input terminals on the MPP unit with the panels connected, 90 volts, disconnect the panels and the voltage at the terminals is 55 volts. Completely remove the solar input wires and it's still 55 volts. The 120 volt output is still working no problem, just no charging.
Before I contact Ian, as it's still under warranty, am I looking at a new MPPT board, or can anyone suggest any alternatives to the problem that I've overlooked?
