Realizing that it's intended use is primarily intermittent and not continuous explains a lot. I don't need it to run for 12 hours, 6-8 would do fine. I haven't mentioned the batteries because they are only required by the AiO. I would run strictly off PV if I could and as the MPPT can't handle the load of the inverter by itself, I was wondering if it was even possible.
It is possible, but it means you'll need enough solar to provide at least 700W of power + inefficiency + inverter consumption. If you have a moment where a cloud shades part of the array, are you okay with the inverter shutting down and powering off the load, turning on and off multiple times in partly cloudy situations? Or are you okay with the unit switching to grid when solar is insufficient?
If you go battery-less, you'll need a unit that's capable of that kind of operation. Not all are.
the link you sent says I might expect ~6kWh/m^2/day at my location.
PVWatts gives good average. There will be some days you blow that out of the water and other days that solar just stinks. Here's what a 1.5kW array would do at my location, 35° tilt and 180° facing:
I'm in AZ, so my numbers are pretty solarly sexy.
If you're just looking at seasonal usage, it would be ideal to tilt your panels to the optimal angle for that season.
If I understand this (and that's a BIG IF), I might expect to enough PV for about 3 hours of operation/day depending on the size of my array. I'm assuming a bell shaped power curve similar to the one you showed before with enough power available only during the middle 1/3. Does that make sense?
Conceptually, yes. There are other ways to spread out the solar. If you had a 1000W array facing SSE and another 1000W array facing SSW, you could widen the peak output period of the day and lower the highest peak. Sketched very crudely here:
This unit:
watts247.com
Can accept up to 4kW PV and can run without a battery (though it's VERY hard to get 4kW PV on this inverter with the 250Voc and 18A PV input limits.
You could plug this into a wall output to provide AC input (fabricate your own power cord, or cut an extension cord).
Set priority to SUB (solar, utility, battery)
Solar energy provides power to the loads as first priority. If solar energy is not sufficient to power all connected loads, solar and utility will power loads at the same time. Battery provides power to the loads only when solar energy is not sufficient and there is no utilityI
Attach up to 4kW (3.6kW more reasonably) PV
Attach your load with a timer to the AC output of this unit. You would want a timer that retains its time even when power is off.
Run your load from 9a - 3p
You could have the unit enter idle mode, or even better, turn it off. Even better, have the AC input on a timer as well - turn it off when you have no more PV. THis part is important, because if you leave it on for 24 hours, it will consume 1.2kWh of energy (50W 24/7). You'd want to turn it on when the array can produce 100W and turn it off at the end of the day when it's producing 100W.
Other considerations:
In most locations, even if no permit is required, rooftop mounted solar must comply with NEC2017. This has additional implications that may increase cost by $60-75/panel. Ground mount avoids this.
