I am having trouble finding the correct gauge of wire and fuses or circuit breakers that I should be using. I have an MPP solar pip2024 lv-mk aio inverter/cc
I will be installing it into a converted school bus RV.
I have two litime 12v 100 amp/hr tm batteries that I will connect in series to make 24 volt.
I will connect three jinko solar 275 watt panels in series. The VOC is 39.1. The max PV input voltage of the inverter is 145 volts.
My questions are:
1. What gauge of wire between the batteries and the inverter?
2. Should I use a fuse or a breaker between the batteries and the inverter? If so which one and what size?
3. What gauge of wire should I use to connect my solar panels to the MPP solar 2024 unit?
4. What type of fuse or breaker should I use between the solar panels and the MPP solar unit?
5. Is there anything else I'm missing to make this a safe and well functioning unit?
6. What's the best way to get solar panel wires through the roof of a school bus? The gland that Will recommends on his website appears to be for a smaller gauge wire then I'm going to need for my three 275 watt panels.
Any recommendations of where to buy would be much appreciated.
My questions are:
