MPP Solar Inverter - Oversize the Solar?
Choco
So its common practice to oversize residential inverters, but is it ok to oversize the MPP Solar units, I cant help but feel they are a bit more sensitive?
Should I stay within the specs, or can I push certain areas?
Inverter PIP-5048 MGX
1x MPPT
MPPT Range 120-430V
Max PV input 5000W
Max PV input Voc 450V
Max PV input Current 18A
Solar Panel 315W
Voc 40.1
Vmp 33.7
Isc 9.85
Imp 9.35
Lt.Dan
How many panels are you running?
From speaking with Ian, yes, you can over panel, but NOT over voltage.
