So what should it read (or not read) if the unit is bonding N/G?Just use AC Voltmeter to test the AC Voltage between G and N, G and L.
N/G will be 0V AC (no load connected).So what should it read (or not read) if the unit is bonding N/G?
I’m interested in understanding why?You should install a ground rod, at the inverter location.
Sorry, one more question.Thanks Timselectric for your reply.
"How are you going to make the connection between the generator and inverter input?"
I plan to simply strip the end from an 12g extension cord and secure the bare wires to the AC Input L-N-G terminals. When needed, I'll plug the prong end into the generator's duplex receptacle.
"does your generator have a N/G bonded output?"
No it does not. The Neutral is Floating.
I'll get back to you, shortly.I’m interested in understanding why?
This is so that if a circuits hot finds its way to earth, it will trip the breaker. Rather than possibly hurting, or killing someone.There is no circuit to the dirt. With the exception of lightning (which could be handled at the array frames) what does a ground rod accomplish?
Ok"Does this generator have a GFCI output?"
No GFCI outlet on the generator.
Thanks
Tim
With the dirt(earth) connected to the grounding system it creates a circuit that wouldn’t exist if the ground rod wasn’t there. There is no ‘stray voltage differential’ because the dirt has no interaction with the Source Of Power in an offgrid system.With the earth connected to the grounding system
But NFPA does…and:I would not recommend adding a ground rod at the solar array
I thought NFPA says the panel array grounding rod should not connect to an off-grid residential electrical system so it doesn’t encourage lightning to enter the dwelling as it is not part of the electrical circuit AND there’s the ground loop issue again.But, it does say that any auxiliary ground rod must be connected to the existing grounding system
absoletey positively this....Just use AC Voltmeter to test the AC Voltage between G and N, G and L.
ahh, good thought. I do have one of those testers and did use it previously. However, can't remember if I did the test on battery AND if I tested with the AC input disconnected. I'll check again this weekendabsoletey positively this....
you must measure because calling the manufacturer does not always result in the right answer in todays "special" tech support world...
you can also easily do this by using a receptacle tester such as:
just plug it and switch to battery...real simple; and you should probably have one these types of things in your toolkit anyway ;-)
The grounding system is a protection system, that provides a path back to the source for any fault current that ends up where it shouldn't be. Since things happen beyond our control. That we wouldn't be aware of, until it causes damage, or bodily injury. It's better to cover all possible situations. And connect anything potentially conductive to the grounding system. (Electrical enclosures, metal structures, water and gas piping, earth, and anything else you find on the property) I'm not talking about lighting protection. Lighting protection should be a completely separate system. I don't want to connect my solar array to a ground rod, in close proximity. This will attract lighting to the solar panels. That's something that I want to avoid. And before anyone says that it doesn't "attract" lighting. I'm not saying that it causes lighting to strike. I'm saying that if lighting is going to strike in the vicinity, I don't wantWith the dirt(earth) connected to the grounding system it creates a circuit that wouldn’t exist if the ground rod wasn’t there. There is no ‘stray voltage differential’ because the dirt has no interaction with the Source Of Power in an offgrid system.
I appreciate that. Appreciate your time.That's my opinion on the subject.
Do with it what you will.
So, you got your answers- so did I
And now you know it’s not a good idea.I've seen people claim they've bonded those in/out neutrals because it's claimed to always be a good idea. I myself am unsure.
you do not have to and it’s my opinion that it’s better not to. Panel array should have a rod from the frames.For earthing the LV1012, doesn't one have to?
In battery/solar- within itselfWhere would the system earth any faults, otherwise?
