Confirmed with Ian at Watts247. He provided a workaround of tying the neutrals together (only applicable if hard wired to grid)Prove again to yourself that your MPPSolar 1012 does not make a N-G bond
Are you implying the ground conductor that is running back to the main panel suffices as the ground for the MPP?run the safety ground back to the panel along with everything else
Generator is open and is sitting inside my shed.if the generator chassis is exposed to dirt or other “grounded” item/surface
Thanks,
Jeff
