Capt Bill
Sailing Options
LV22424 Fault Code 01 = "Fan locked". .... I have 3 MPP LV2424 All In Ones networked together for 240vac Split Phase output. I just pulled a 4th unit out if it's box which I have had in storage for 6 plus months. I am updating from three units to four ... to have full 40 amps ac x 2 for a Level 2 EV Charger, for an electric vehicle I see in my future that I intend to charge up via solar. ... I just got Fault Code 01 on one of my 3 configured and running LV2424 units. The fan noise also stopped when the others were working and heard. The alert beeping got my attention. IMO: That is a good reason to leave alarm beeps on, vs turning em off/ my set up is in back room) .
... Has anyone else had to deal with Fault Code 01 on an LV2424 ?
Interesting to me: This 4th unit I am getting ready to install on my solar wall is a slightly later version that my other 3. I hope the firmware in em match up properly without needing to update any of them (will see). ... Something new: The external housing has an course anti static type air filter with a thin metal housing held next to the top side vents (attached by one screw on top). ... There is a new "Clearance And Maintenance for Anit-Dust Kit sheet in box with picture to encourage cleaning the 2 filters once in awhile. ... Interesting my fan lock code showed on one older unit same day as I notice this change on the new version of LV2424 I just unpacked, and installed parallel kit to. I did also recently noticed some dust accumulation on my 3 up and running units at the top side air holes, which I wiped off on outside housings. I do not have a particularly dusty room where these are installed, but I can see that dust can accumulate over time.
Has anyone else had to deal with that Fault Code 1? I will taking the housing of that unit off next. I expect a locked fan could be a bug that crawled into the fan, or possibly lots of dust (seems unlikely?), or a burnt out fan. ... If is see dust in the Fault Code 1 unit, I will also blow out the other two, ... and wonder if I could get the new filter kits from a MPP supplier in the USA. I will update this post later.
