I purchased an LV2424 MSD and have 2-12v, 100Amp hour LiFePO4 batteries is series. Erik, I noted when you started this post that your unit was trickle charging the batteries at around 1 A and also noted that your readout was showing around 75% charged when, according to the battery voltage, it should have been 100% or close to it. Did you ever resolve this issue? The reason I ask is that mine (which i just connected everything yesterday) show 27.2v which, according to the battery specs (SOK batteries) should be at 100%, but the readout is showing 70%. It is charging the batteries but not trickling. I have it set at 20A charge from solar (did not tie in my mains power yet, nor any loads) and that is what the readout indicated. I checked the batteries wire with a clamp-style Amp meter and, sure enough, it was reading around 20A. I let it run all day and even after several hours the readout still indicated 27.2V on the batteries and 70% charged. The charge to batteries was still 20A. After the sun set and no PV power, the battery dropped to 26.5V (80%) and stayed there overnight. Of course, the ony load was the 3W or so the LV2424 unit uses. My settings are bulk charge 28.4V and float of 27V. I have the float set low since LiFePO4 batteries don't need float (as i understand it). I did note that in your inital post that you had the float set much higher. Could that be my problem? Also, if the batteries state of charge was not balanced initally, could that be causing the issue? The unit works fine otherwise, i just don't like the fact that it seems to be charging the batteries when they appear to be full (confirmed the 27.2V reading with voltmeter by the way). My intention is to leave everything as is for today and see what happens but if it seeems to be feeding 20A to the battteries when the voltage indicates 100% charge, then I have a real cocern with the unit. I don't want it to damage the batteries. They do have BMS's but i shouldn't have to rely on those. The LV2424 should know when the batteries are fully charged and stop charging. Thanks in advance for any feedback.
