So I've been experimenting with my parallel LV2424 units, and noticed that the utility connection ports (when disconnected from grid) show a voltage of up to ~0.8 volts on each unit. The units in parallel have read as high as ~1.8 volts. I have the grid-tie feature disabled in settings, and would thus expect the utility hookup to always read at zero volts.
I mentioned this to a friend, who works for our local electric co-op but is not an electrician, who suggested that this would make connecting these inverters to the grid unsafe, as when that voltage reaches the transformer it will be stepped up to somewhere in the neighborhood of 110-120 volts. They stated that the co-op would not allow these devices on the grid if they produce more than zero volts at the meter.
I was hoping to be able to use the grid bypass & charging features of the unit, but I'm now concerned. I know the unit isn't UL-listed, but I assumed that only related to the grid-tie/backfeed functionality, and had read on these forums that the LV2424 is expected to receive a UL listing in 2020 anyway.
Could any other MPP owners chime in? Do your inverters show a non-zero voltage on their utility connection ports? Perhaps I have some induced voltage, or another problem?
