MPP solar LV6048 bus voltage is to high
Eco@242
Hi to everyone.
I'm Constantine. I'm new to the forum and to solar.
I am trying to finally back feed to the grid, but this fault code came up(08 buss voltage is too high). How do I fix this?
More things can cause the Error 08
The bus voltage is 373-400V in these inverters.
This has to go over 500V to get this error message.
(or at least in the EU version ... so I am not sure this is the same in the LV inverters :) )
What can cause it:
  1. PV over voltage. How many solar panels do you have in serial, Voc, Vmpp, V temperature % ?
  2. Backfeed on the AC out (load) side. A generator, a bad UPS, or a grid-tie (micro) inverter ?
  3. Earth leakage. Mainly in rainy days if a solar panel leaks to earth.
  4. An old firmware bug caused regularly in 2-6 am to stop inverter with error 8.
    Try to set 11-max utility charge current to 2A ... and 16-charger source priority to CSO (solar first)
Reactions: Rho
Hey,
Thanks mrzed001.
I think your rite about the backfeed part. Will have the electrician double check.
Hi to everyone.
Hi everyone, I'm experiencing this problem Error code08, It happens around 0300hr to 0500hr everyday.... I have confirm the utility grid power is stable during that time period.
Is there a solution to this problem?
