SolarEddie
- Sep 19, 2022
- 21
Hello all, I’m trying to understand the wiring diagram and circuit breaker requirements from the main breaker to 5 LV6548 inverters AC inputs, then the 5 inverters AC output to a sub panel?
Inverters 1-3 are in 1st phase, inverters 4-5 are in 2nd phase.
Plan is to program LV6548’s to provide power by priority: 1) 19.6kW rooftop solar; 2) 41kW batteries; 3) grid.
What I have gathered from other threads, for split phase with two units I would install a 60a 2-pole circuit breaker on main panel and run one hot to 1st phase inverter and one hot to 2nd phase inverter. Then I would run AC output for both inverters to the sub panel to another 60a 2-pole circuit breaker.
Not sure how to configure this for 5 inverters?
Also, intermittently to reduce idle energy consumption and when high demand is not necessary, the plan is to turn off inverters 2-3 of 1st phase and inverter 5 of 2nd phase to run system with 2 units in split phase.
I have not purchased the sub panel yet, the main panel is a Square D Homeline, so any input on sub panel models with 40 spaces or more in the same line would be appreciated so I can recycle all the current circuit breakers by transferring them to the sub panel. I’ve also considered a “smart” sub panel (i.e. Lumin) for load management. Experience in this area is appreciated as well.
Thanks for any guidance.
