schmism
my dual growatt spf 3000 together pull ~70w when in grid bypass
Wow. Id go for the mpp solar units thenFYI, just an update on a question I had sent to both vendors for the MPP LV6548 and the Growatt SPF 12000DVM, about idle power draw.
Peggy responded that the LV6548: "...stand by power consumption is around 25-30Watt "
(not sure if that is for pair or single unit, I specifically asked about 'pair of these' in my original question to her)
And seller of the Growatt SPF 12000DVM indicated: "Idle draw on the 12kw is 150W"
Yep, I just bought a pair of the LV6548's.... Now just gotta wait and hope the boat has big turbos on it and gets here fast, they said it takes 3 days before they even ship so they can do full bench test on them...
Interesting; from my perspective of just dialing my my 3 x MPP LV2424 onmy 1st DIY 24v LiFePO4 build, configured for 240vac split phase; while wondering if I might ever try something of MPP line in bigger 48v sizes; ... wondering about your "most of the limits" re LV5048. If you would not mind: Which limits do you notice that you see the LV6548 eliminating. Curious, especially as I think about friends asking my about my takes on their DIY options.Imagine most of the limits the LV5048 has when it is paralleled, the VL6548 eliminates those issues.
P.S. Re: My LV2424s limitiations (sure there must be other on top of night time idle draw, x 3 for me, whcih is higher han some other possible choices); I like my LV2424 for now, but the one limitation I do not like is; ... even though each of my 3 LV2424s has a up to 60 amp in to battery - grid powered battery charger option in em; when the LV2424s are configure for 240ac split phase; to get an inverter generator powered battery charge cycle going, the owner/operator must supply 240vac split phase to (I believe) entire line of LV242, an there NO Grid Charge can comes on line from applying just 120vac to one LV2424 unit . So there is No way to for me charge my batteries with my good 4000 Watt 120vac Inverter Generator unless I reconfigure one of my LV2424s back to single use mode, (and likely fully disconnect the others)... At least I figured out a back up plan, workaround idea (just previously mentioned) for if I ever wanted to, or needed to charge up my LiFePO4 battery bank on some long cloudy day cycle while powering up my house sub panel with my 120vac inverter generator. I wonder if that is the same story for the battery charger in the LLV5048, and LV6548 ? Questions from just reading about LV5048 limitations.
:+) Bill
Thanks for pitch, ...got me looking for hard to find specs/ ... Glad to consider options. Happy Days, BillPerhaps you could use one of these datacenter SURT003 split-phase transformers like this:
APC SURT003 Smart UPS Uninterruptible Power Supply | eBay
Model Number: SURT003. Manufacturer: APC. We would also allow local pick up for this order. Item Location. Condition: Used. Testing: Untested.www.ebay.com
...to plug in between your generator 240v single-phase and the MPPs...
This is what I have in my Prius wired after my SURT5000XLT inverter. They provide split-phase output...
There are other options for split-phase transformers too of course, but these are convenient and fairly inexpensive to acquire used, if you shop around. They are rated at 30a input. They are heavy though...
EDIT:
NEVERMIND, I re-read the part, you said your generator is 120v, disregard...
I know ACME has some transformers you might be able to use for step-up with center-tap secondary winding... Probably not worth it...
Re: Idle use draws: My 3x LV2424s show a 6 amp draw on BMS that kind of matches both LV2424 battery draw info. plus another forum member saying his LV2424 has about a 50 watt idle draw. The newer bigger model looks attractive, like a good bang for the buck. Wow Samsonite: That new LV6548 look good, and like a great project to put on line. Hope to keep tack of your posts here. :+)My LV5048 x 2 do 20~30 watts at idle (night)
Listen to me very carefully.Ha, I don't even have a house or a pole barn to install them in yet! I might have to install them into the basement of my motorhome and it can double as a heater for the Winter... I'll get there though, just a slow and patient road I must follow
I will post updates though, as the project unfolds. The plan was, I will eventually get a Sol-Ark in the long run, but this experiment, it was more in my starting budget to get the MPP, to be something that will last for 2-3 years or so, be very cost effective, have good reviews, etc, so I can start building structures sooner...
Still need a well, septic, pole barn, passive home, greenhouse, garden, orchard, and I'm out of money now (don't worry, I got this, just takes time is all)... At least, I am grateful to the skies above that I am able, and have a decent job and a set of goals...
This is not going to work on a motorhome.
So, send it to me until you get your barn and greenhouse up. I will watch over them and send postcards and take selfies of them so you know it is happy and waiting. Trust me, I turn solar power in the driving miles!
I would seriously consider MPP's LV2424 for a motor home option. It connects up to a 24vdc battery bank, can take in up to 2000 watts of of Solar panel input, while able to function on less much less., plus has a 60 amp grid powered, or inverter generator powered battery charger in it. Something to ponder :+)Dang, I was afraid of that... Well I might also need a place to store all the 32 LiFePO4 cells and a bunch of other stuff too, you have more room for that too?
I have 64 somewhere out the Pacific Ocean. But since you mention it, I can put a few cycles on your 32 just to keep them active. Electrons just sitting there not going back and forth across the membrane can't be good for their morale.Dang, I was afraid of that... Well I might also need a place to store all the 32 LiFePO4 cells and a bunch of other stuff too, you have more room for that too?
I do this already for the past full year. I run my entire house on the pair (LV5048 previous model).I'm thinking of using two of the LV6548's for a split phase grid tie (no back feed) set up. This would be for my vacation/rental house in Jamaica. My PV size would be roughly 8kw and 8.5kwh of LifePo4 Batteries.
For wiring to my house, I was thinking of interrupting the main after the meter to a new breaker panel and then from there to the LV6548's with the load side going to the breaker in the house. Would this be a good setup?
Thanks! I can always add more batteries. One more question, I read the manual and having seen anything about power share. If the load is more than what the inverter can do, does it completely switch over to grid?I do this already for the past full year. I run my entire house on the pair (LV5048 previous model).
Think of it like this;
Solar and Grid --> LV6548 --> House
This is Grid-Connected, not grid-tied. Grid-Tied means back feed or "bi-directional".
Your battery bank is not very big, but as long as you have no more than 2 days of clouds in a row, you will be fine, and since you do have the grid-connected as the input, you won't have to worry about being without power.
