Is that a ANL Fuse, isn't that a 32v Max, that @Will Prowse said is insufficient for a 48VCD bank?For your viewing pleasure...cheers
Just because it looks like anl does not mean it is one. It looks more like a megafuse (which has a higher voltage rating and AIC), but impossible to tell with that photo. If you can take it apart and take a high detail photo, we may be able to tell.View attachment 94356
Yes, absolutely. Totally different inverter.Looks like the WP is actually significantly different from the non-WP
Will, I have two of the LV6548's just like you have, and love them. I just purchased two of the WP units for my other home in the south, which has a large pool, well pumps, etc, currently running on SMA inverters. I want to be able to handle a power outage though. I had thought the WP version of the MPP would be outdoor rated and Low Frequency, but the specs show 1ms over current to 90 amps per phase, which seems like a High Frequency limit.Yes, absolutely. Totally different inverter.
Deye and Voltronics are two different companies. MPP uses Voltronics, and Sol-Ark uses Deye.Im sorry to break the News, But it seemed fishy when I saw a very similar looking Deye inverter and I took the liberty to ask. Even the connectors inside are similar:
View attachment 94354View attachment 94355
Exactly my point. Im suggesting that Maybe, just maybe, this time Mpp Solar sourced this inverter from Deye.Deye and Voltronics are two different companies. MPP uses Voltronics, and Sol-Ark uses Deye.
It's VoltronicsExactly my point. Im suggesting that Maybe, just maybe, this time Mpp Solar sourced this inverter from Deye.
Oh Well, Was hoping for an increase in quality.It's Voltronics
Deye/Sol-ark have their own issues.Oh Well, Was hoping for an increase in quality.
Anybody knows what type of fuse is that. Looks great for our Setup and 80VDC rated.Fuse
Wouldnt having two in parallel decrease the chances of having issues with inductive loads? My induction stove uses up to 3600 watts.I have one LVX6048. it starts and runs everything in my home except my 5 hp air compressor.
It just growls and cant quite get the lead out starting that 5 hp motor. It runs my
old south bend lathes, skillsaw, well pump, heat pump hot water heater, dryer (but the dryer really kicks it into high gear.)
Lathes are 1 hp motors. It has no issues starting that deep well pump at all. The dryer I put back on the grid because it seems to use over 4000 watts to run it and I do not want issues when the well pump starts up.
We recently had a grid outage that lasted 4 days. I was unaffected here except that I used a clothes line to dry my laundry.
I am telling you, it made it all worthwhile in those 4 days.
It should, especially if its a 240V inductive load.Wouldnt having two in parallel decrease the chances of having issues with inductive loads? My induction stove uses up to 3600 watts.
I think it very likely that 2 would start my 5 hp compressor. If I ever buy another, That will be the first thing I try.Wouldnt having two in parallel decrease the chances of having issues with inductive loads? My induction stove uses up to 3600 watts.
I have two LV6548's at my current house, and I have no issues. HVAC, tools, compressors, chop saws, all good.I think it very likely that 2 would start my 5 hp compressor. If I ever buy another, That will be the first thing I try.
It starts ALL my other power tools even though many are 120V. That is a huge deal to me. I will be installing a 2 ton ground loop
geothermal unit later this year. If that did not run. then for sure I would get a second LVX6048.
How many HVAC tons are you running with Lv6548?I have two LV6548's at my current house, and I have no issues. HVAC, tools, compressors, chop saws, all good.
My new home has a well pump, and that is why I wanted a low frequency inverter.
3 ton Tranes. I did put a soft start on them though.How many HVAC tons are you running with Lv6548?
