I'll chime in.
I've been running a TP6048 (sungolds version) since mid October with nearly 0 issues.
It's being fed by the grid, 2 arrays (~360 voc) , and 22kwh of DIY lifepo4.
It's feeding my entire house (except the 240v electric stove and dryer)
During cloudy days the grid takes over when the battery voltage drops below the voltage setpoint I entered.
I was able to program it to charge from grid during set hours as well as change the charge current with no issues.
I've had zero issues starting / running : 1hp 240V well pump @300+ft, 1hp 240v air compressor charged to around 85psi, 240 furnace hvac blower, standard top load washing machine, microwave, counter top convection oven, 120v oil filled radiator, etc. (obviously not all at the same time).
According to the display I've seen imbalances between L1 and L2 as much as 60%.
My main complaints, the software is pretty shitty. I was able to connect with a USB cable and read data but it's slow and doesn't always save/pull data.
I have a noticeable flicker in the lights (led) when the washing machine agitates.
It's really loud when arrays are making good power.
At this point I wouldn't hesitate to buy another one.
I'm hesitant to even bother with firmware updates because it's working good enough.
Any questions or testing I can do, ask and suggest away. I wouldn't be where I am with solar without all of you and this forum.
