Awakenhorizon
- Mar 5, 2022
- 17
Hello, I'm in the process of ordering cables and after checking the manual for the PIP-1012LV-MK 1000W it's not very clear on the lug size. I have a 12v 200ah Jita LiFePO4 battery being shipped and wanna order some custom made 2AWG 4ft cables (I hear going bigger is ok, right?) but the options for lugs are 3/8 & 5/16. I tried to zoom in on the demo video and it looks like 2-3/8 is stamped on the lugs but not sure. Also, not sure of what size the battery lugs will be, so should I just go with 3/8 on both ends, or is it 3/8 one side and 5/16 the other side, or just 5/16 all the way? And from the battery should I just add a bolt on 100A or 250A fuse? Or is it better to go with a 100A or 250A manual circuit breaker? I'm not sure if it's the battery's 200ah that determines this or the 80A MPPT/1000W inverter/60A charger that determines the fuse sizes.
Also, with six 100W solar panels from Newpowa (specs below) is 20ft 10 AWG good enough for running them as series in sets of 3 and then parallel the sets with a 10A inline fuse for each set?
Thanks in advance! This is my first setup and I'm looking to install the panels on my deck at a south-facing apartment that gets great sun exposure. ?
Specifications
- Dimension: 33.70*26.57*1.18 inches
- Weight: 14 lbs
- Max Power Output(W): 100W
- Voltage MPP Vmp(V): 16.77V
- Current MPP Imp(A): 6.26A
- Voltage Open Circuit Voc(V): 19.83V
- Short Circuit Current Isc(A): 6.56A
