Building a small portable system around a 2.3 KW LiFePo4 battery bank and a MPP Solar PIP2724LV-MR. I'm trying to decide what panels to buy. The Inverter/Charger has a 25 amp MPPT charge controller built in. The max pv VOC is 60V and the max pv input is 600 watts. I was planning to run two 72 cell panels in parallel. As long as I stay under the 25 amp maximum short circuit current am I okay to exceed the 600 watts? I was planning on running two 350 watt panels.
A second question is what do y'all recommend for a BMS? I was planning on using a 150 amp Daly.
Thanks,
Nathan
Thanks,
Nathan
