matt2006
DIY Solar since 2016
I am an off grid solar technician and I have a customer's MPP Solar Inverter all-in-one that has a display that stopped working.
It's a 48VDC 3000W model
PIP3048LV-MK
The display is not coming on (it flashes dimly)
It still outputs power from the battery.
I have attached some pictures.
There is a 4pin connector on the display that's unplugged.
I'm not sure if that should be plugged in; I do not see a port for it.
Anyone have experience with the display on these things?
I think its a common display used on so many of these all-in-ones.
UNIT seems to be from 2020
SCREEN board says
PCB1-B00252A-A
And on a sticker says:
12-400144-00G
XRDZ-B00252AHUTBWNNN-2
202025A01865
Thanks for any help!
It helps out my customers that need to save money.
PIP3048LV-MK
SCREEN board says
PCB1-B00252A-A
12-400144-00G
202025A01865
20221109_101134 Mpp Solar PIP3048LV-MK Troubleshooting, LCD display board model.jpg201.4 KB · Views: 5
20221109_100703 MPP Solar PIP3048LV-MK Troubleshooting screen not working.jpg91.5 KB · Views: 6
20221109_100706 MPP Solar PIP3048LV-MK AC voltage output.jpg282.2 KB · Views: 4
20221109_100723 MPP Solar PIP3048LV-MK DC voltage input.jpg281.7 KB · Views: 5
20221109_100751 MPP Solar PIP3048LV-MK SPEC SHEET and serial number 92812007100372.jpg157.4 KB · Views: 5
20221109_101158 MPP Solar PIP3048LV-MK Troubleshooting, 4pin cable disconnected from LCD displ...jpg147.8 KB · Views: 5
