Hello All.
I'm in the market for another inverter.
I currently have a MPP PIP-4048 with 16 X 130ah Winstone cells which has been running fine for 4 or 5 years now. Serving about half the house. For most of that time back to grid was set at 48V and charge stopped at 54.5V...The cells were in perfect balance, no BMS.
3kw of solar, North, East and west (120cell strings into the PWM controller) (West to be upgraded to 1200W and the existing 1000 moving East)
Added another 1600W of panels with a MPPT controller a few years ago. (That cheap makeskyblue MPPT has been going well )
There is also a 1500W grid tie inverter doing its thing and i'm in melb australia.
End up at 7.3Kw solar and no roof space.
Problems
The issue with a 3V cell cutoff on a small bank is voltage sag under load sometimes leaves quite a bit of capacity on the table.
So as cell prices have come down so much I felt emboldened to adjusted the low voltage on my existing cells to get a bit more capacity
I should have left it alone, as 44V (2.75V cell) has high lighted some cells which then causes issues with balance at the top.
(Dumb Active balance now on the cells.)
I now have an order in for 280ah cells with Amy Peng, (the other Amy wanting +%25) and ordered a JK 200amp BMS.
I'm eyeing off the 1500W of panels currently connected to the grid tie inverter, and the 4Kw inverter is not ideal for some lumpy circuits.
So an inverter with MPPT and more WATTS is on the shopping list.
So many choices and so much BS floating around.
I'm seeing inverters with 5500W and MPPT but which one?
MPP seems to top out at 5000W with the HV2-5048 before moving into a different price bracket.
Others similar to 5048 claim 5500W and a lower price than the HV2-5048. (I'm not interested in feeding back to the grid, the tariff is next to useless).
I see MPP claiming others are fake and copy's but my research years ago had Voltronic Power as the OEM of the MPP range.
I'm a out of touch with what is current and best value, what brands should not be touched ever. Hence putting up this thread to solicit opinions.
Problems
