scrooster
W = V² / R
MPP Solar: "No."
You might check your pump specs with watts247.com as I believe they offer those as well.
Ground level with the base about 4' below the house. They have a 1/2hp jet pump and a pressure tank to provide pressure to the house.
He's acquired a rebranded Sigineer 6kW/24V inverter with 18kW surge. Both Sigineer and Electric Car Parts Company (distributor) confirmed it should work. He's waiting for his well pump guy to do the wiring.
So he needs juice for the pump AND the pressure tank?
First off, as everyone else has stated, he needs to simplify his pump/power issues. Hedges is all over it ... he's nailed it. Great advice.
Secondly your neighbor needs to elevate his storage tanks and let gravity do the work. Make sure he has a proper redundant backflow valve system in place and that his tanks stay topped-off, free of direct UV (deterioration) ray issues and properly, periodically, treated. He can also step down his service lines from the tank to increase water pressure.
I'm running off of eight caged, covered and enclosed IBC containers that are linked in series, self leveling and elevated 7' off the ground. That's 2000 gals of water sitting in a platform built on 6x6 treated posts with 2x12 treated joists and all of the containers have backflow valves inbetween in case of a rupture or penetration in one tank for whatever reasons ... and the entire set-up, including the tin roof covering amd siding which is easy if you're using 24' posts, cost me a little over $3k, tanks included. No more need for pressure tanks. Plenty of water if the grid goes down until I can make sure that at least one of my wells are up and running again on solar or gennies. This system also facilitates getting your tanks full, and longer lasting, with one cycle verses having to run your pump (or genny) over and over again.
Back to the pump issues ... Hedges laid that out nicely. And I'm thankful we do not have to drill much beyond 300' for good water here, often less.
I do not see how anyone can expect long pump life on the 500-1000 feet wells without going 3-Phase. I'm not a well driller nor am I an electrician but I know a few, including my brother in law who dug all three wells on this property and who digs a bunch of 500'+ wells for these big time farmers around here ... and I just talked to him and he said he would never install anything less than 3-phase at that depth ('700) if for nothing else to save big money on the wire alone.
With that said I do, and have, run my 300'+ well with a 1½ pump on a 5kw gennie no problems, although I've got a 14kw genny now.
Back to the cistern above ground storage for a moment. We're here in SC with an avg mean temp of 72° and it very very rarely gets below and stays below 32° around here .... but I still covered and enclosed my tanks just to be sure. If your neighbor is somewhere where it does get below freezing for extended periods of time ... he has to enclose his tanks and insulate and have available 120 power to run a small space heater to prevent freezing of course ... that goes without saying but I did it anyway.
ETA: Just talked to the BIL and he said, fwiw, he believes that a '700 residential well could be run on a Hallmark rated as a 3 HP, 230V/60HZ single phase motor (here's the model # he gave me and I hope I typed it correctly ma0431x-18a-e) and he said he thinks it comes with 250' of wire but the pump is good to 700' and it has a built in capacitor to help with start up so the 14kw genny will work fine according to him but you'll need minimum 4" casing to drop that pump. He said to call Hallmark and double check him to make sure. Here's the number he gave me 847-301-8050 and ask for Henry.
FWIW BIL also said that based upon your curve and head, and if that water is 700' deep in a 1000 foot well ... you're going to need a minimum 7hp pump to draw anything near 15 gpm.
Anyways, that's all a fwiw. I hope I conveyed what he was saying correctly ... he stressed it's all about where the water is, not how deep the well actually is. He said he's hit good water at 200' but still dug a 500' well and dropped 6" casing based upon usage requirements and that I didn't really provide him enough information to know for sure how to answer. He's assuming your water table is somewhere around 400' on a 700' deep well.
ETA2: And you've got to get all of the above figured-out before you start buying inverters and panels and building battery banks, etc.
