Those are 195W panels, not 200W. They are also very expensive ($1/W). Do you already have them? You can easily find panels closer to $0.50/W.
They don't even list all of the specs. They don't show the Vmp. You can calculate the Vmp since W = Vmp x Imp. Assuming what they list as Iop is really Imp then 195W / 9.02A = 21.62V. But that can't be right. Voc is 21.6V. Vmp is always about 80% of Voc. So what they list as Voc is really the Vmp. Voc should be more like 26.6V. Another reason to avoid these panels if you don't have them already - they can't even post the correct and full specs.
If you already have them then they will work. The max PV input voltage of the SCC is 105V on a 24V system. If my calculations about the specs are correct, then you can't put the panels in 4S, you must put them in 2S2P. At 4S the Voc would be 106.4V. That's too high.
