MattMan119
Solar Geek
So, i though ok, let's build a cheap little solar system to keep the freezer running when the coffee truck is parked overnight at fairs. It was also used during the hurricane.
One of the "cheep" things I used in this test was
Now that said, it appears to keep charging even after all it full forcing the battery to shut down or causing the inverter to have "High Voltage" warning or error.
Should I just give up on it, and install blue, or does someone have a good idea .. The charging other than not stopping works good (or it appears too anyhow)
BTW: Connect to 24v - 2 lithium batteries.
100A MPPT Solar Charge Controller 12V 24V 36V 48V LCD Display Battery Intelligent Regulator Max 100V Input Dual USB for Lead-Acid/Lithium (100A)
