I have a Victron 150/## MPPT that shows battery voltage level (eg 52V) as PV voltage at night when it should show near zero
Upon researching it appears the most likely reason is a broken reverse diode.
Victron staff commenting on identical issue:
“the charger should switch to off mode during the night and the panel voltage should go down to (almost) zero. If this is not the case, the most obvious cause is that the reverse diode is broken, this causes the battery voltage to remain visible on the panel connectors.” (https://community.victronenergy.com/questions/6134/10020-odd-behavior-at-night.html)
However, I’d been running the MPPT perfectly fine in my 48v system for more than a month before I even noticed. i only realized this was abnormal after I added a second charge controller and saw it’s PV voltage near zero and started asking questions.
Victron is happily replacing the unit (excellent service)…
But what ill effects Could the broken reverse diode cause that I’m not realizing?
They told me to dispose of the faulty unit after I receive replacement, and I’m considering reselling it instead (of course with flaws fully disclosed and no warranty), but I don’t want to do that if theres any safety issue or other unacceptable ill effects from the broken reverse diode that go well beyond just a bad PV voltage reading at night or other very minor negative effects.
