rin67630
I have already explained a couple of times here, why one should NOT use an MPPT controller between a nominal 12V solar panel (Voc~17-18V) and a 12V battery.
MPPT controllers need a good voltage difference to be able to find the right MPPT value under all weather conditions.
Nominal 12V solar panels are optimized to be used with 12 V batteries with a PWM controller, not an MPPT controller.
Now what could you do if you have to start with a nominal 12V solar panel and want to get all the advantages of MPPT operation?
You basically have two solutions:
a: Use a 6V battery (or a 7,2V one) That solution works quite well if your MPPT controller can be adjusted to that battery voltage.
b: Use a 24V or higher voltage battery, together with a boosting MPPT solar controller.
A boosting MPPT solar controller ???
Yes, boosting MPPT solar controllers exist and will permit you to charge 24V or 36V batteries or even higher (like what you have in e Bikes) from a single 12V 100W panel, and they do it quite well !
Counter-intuitively, in the world of DC-DC converters, boosting converters are the most efficient ones, easily reaching 98% where a voltage reducing buck converter will do hard to get better than 92%.
An example of a boosting MPPT solar controller is the MingHe Solar Charge controller.
Boosting MPPT
Okay, it is a cheap Chinese stuff, but I know the company, it is the company behind the JUNTEK and the DROK DC-DC converter which I have been using and I know they are doing seriously engineered products.
That is surely worth to give a try...
Boosting MPPT
