Scott J Martin
I have 9 Yuma CIGS 200W Panels from BougeRV. I plan to serial connect them into 3 arrays of 3 panels each.
I have 3 Victron MPPT 150/70 controllers.
I have 2 LiTime 12V - 560Ah batteries connected in Series
Volts Volts with 20%
Voltage - Open Circuit - Voc 30.4Volts 36.48Volts with 20% buffer.
3 Three Panels at 36.48 = 109.44V. Each MPPT Controller can handle 150Volts
Maximum power from PV Arrays 200 Watts per Panel, Three Panels = 600 Watts per Array
Output Current (600W divided by 14.4 Volts)
600 Watts / 14.4Volts = 41.7 Amps time 1.2 for the buffer = 50.0Amps. Each MPPT Controller can handle 70Amps
The Batteries' Specs say :
- "Recommended Charge Current - 112A (0.2C)
and
- "Max Continuous Charge Current - 250A
Am I going to exceed the "Recommended Charge Current"?
and
