mrbf and zcase fuse observations and questions
John Frum
Tell me your problems
MEGA/AMG/BF2 – Current ratings from 60 to 275 amp, these are used for starters, alternators, and batteries. They are a bolt-down fuse and are slow blow. These fuses measure 19 x 68 mm.
MRBF/ZCASE – This is a single MEGA type fuse that is used for very high current application, most commonly the starter. It is mounted with a single bolt. Fuse ratings range from 40 to 250 amp.
The ZCASE Masterfuse product is the smallest high current distribution product in the industry. It utilizes the Z-Axis effectively to create a compact design which takes 1/3 the footprint of a traditional solution.
MRBF= Marine Rated Battery Fuse
  • The fuse design is optimized for a one bolt connection M6 and can be used directly on a battery post or busbar connection.
