packrat1969
- Nov 30, 2021
- 32
Hello,
I'm in the process of building my second 12V LiFePo4 battery. This time around I'm using Eve 304Ah cells with the double-bolt-style terminal (correct me if there is a proper name for it). These terminals use (2) 6mm bolts instead of having a single stud like my last battery build.
I'm looking for some kind of low-profile fuse holder that will bolt directly to the cell terminal, using both 6mm fasteners. I would prefer to use a Class T fuse, but if that is not available, what about an MRBF fuse and fuse holder? My plan is that the fuse holder will be the last stop for the (2) 4ga wires before the battery's bulkhead +12v terminal. Once installed, all wiring will be fastened in place so I don't see this putting much strain on the battery terminal.
I've physically tested the Blue Sea hardware and I do not have enough space inside the battery box for their 5502 Class T fuse holder (using a 250A fuse).
The 5191 MRBF holder has a single 3/8" (10mm) terminal hole which leaves a lot of slop when fastening it with a single 6mm bolt.
I've been thinking that I probably make something custom out of copper for the MRBF-style fuse but I wanted to see if someone knows of anything that already exists before I reinvent the wheel. Anyone been here before?
packrat
packrat
