Do you mean MRBF=marine rated battery fuse?I will have 4 12v batteries. I do have 2 class T fuse in hand. But I am going to put an Mbr fuse on each battery and, then a 200 Amp Blue Sea breaker after the fuse and then into a victron power in. Is this safe?
300 ah MRBF on terminal fuses.I will have 4 12v batteries. I do have 2 class T fuse in hand. But I am going to put an Mbr fuse on each battery and, then a 200 Amp Blue Sea breaker after the fuse and then into a
Fuses are rated in amps not amp hours.300 ah MRBF on terminal fuses.
You asked what the Amp hour rating of the batteries were.Fuses are rated in amps not amp hours.
Yeah I ordered 4 and 2 spares.I bought my same style fuse from baymarine, they were very good to deal with, and when a couple items were missing on arrival they promptly sent those items at their shipping cost.
Bussmann MRBF Terminal Fuse Block
Bussmann MRBF Fuse Holders - Select your version above! Convenient MRBF fuse block places your MRBF fuse right at the battery where it need to be for maximum circuit protection!baymarinesupply.com
The Bms rating is 150 amp for each battery. 200 for the circuit breakers is enough.. at least I hope so.The Class T fuse size depends on how much you're going to draw from the battery bank. At first blush, 200 amp seems undersized.
4x separate bms . JBD 150 amp... 4/0 wireWhat is the size of the wire conductor you are using to connect to battery? What bms is it?
I'll have 4 300ah batteries each one will have a 150 amp BMS
300 amp Terminal fuses on each battery
going into a blue sea 200 amp Circuit breaker on each Battery 4/0 cable
then into the Battery Combiner (Victron Power IN)
400 amp mega fuse in Victron Power Distributor.
