I'm getting ready to roll my first Lifepo4 battery with a Morningstar PS-MPPT-40M charge controller, Chargery BMS, and Samlex PST-3000W 24V inverter. I pleasantly found out I can use PIN 3 of the Samlex to switch the inverter on with 4.8milliamps at 24V! Yippee!
I can use the low current relay voltage from the Chargery to cycle the power off on the Samlex for BMS faults. Yeah!
I'm looking for a similar low current solution to turn off the PS-MPPT-40M charge controller. Morningstar suggested looking at MODBUS "coil settings." MSView is the MODBUS programming interface that MorningStar uses.
Does anyone have an idea of which MODBUS parameter I should program. It seems to me I could use either a low voltage value from the low current relay from the Chargery BMS, or high voltage value from the Chargery BMS alarm output to feed a "coil setting" that would trigger a shutdown of the PS-MPPT-40M.
Does anyone have a suggestion of what parameter in MODBUS or MSView to use? My next step is to go through the MSView ProStar MPPT and RD-1 relay driver wizards to get hints.
I'm sure someone has some insights.
Thanks.
Thanks.
