Multi-Use Solar Trailer Grounding Questions
Bongos
NY
I have a bit of questions regarding my new potential setup project.
I am looking to put 8 410w panels on a wooden frame mounted to a trailer that would sit in the driveway in summer and in the backyard in another location in the winter.
I am looking to use an EG4 3000EHV-48 again for this setup. But it will be used similar to the handcart builds.
So my questions are surrounding grounding and wiring.
My plan was to leave it plugged in to an outlet in the attached garage most of the time letting it power things with utility as backup, but remain mobile and able to cart around to the other side of the property by being unplugged.
During this i had planned to run a grounding cable from the array on the trailer in with the conductors in a flex conduit to the inverter and let it travel thru the home from the outlet and bond in the main panel to which is connected to both the water pipe coming into the house - and an existing grid tied solar system which is connected to the water pipe as well , but has its array grounded to a separate grounding rod outside the house. (Which confuses me , but was inspected and passed and installed by a major installer)
Now comes the tricky part, when in either the driveway or the backyard positions and disconnected from the house i am now without a ground. So do i put a grounding rod by the driveway and 1 in the backyard with posts with a quick disconnect attached to the ground cable with a switch so that i can connect to and turn on the ground path to whichever rod i am closest to when i move the array on the trailer? Or is there an easier way to do this?
The harder way of doing it i had thought would be to have a switch by the inverter instead for the ground to be Grid or Remote and to leave the grounding rods connected but buried and connected to the other grounding rod hundreds of feet on the other side of the property AND i'm not sure if i would need to connect to the water pipe as well? (this seemed like something i want to avoid having to do) And i'm assuming when they added the grounding rod it became the grounding rod and the water pipe is just considered being grounded to it as well now and i wouldn't need to bother connecting to that as well if i had went this route.
Also is there anything i may be missing in my thinking ? Thanks.
When you are connecting to the house. Use the grounding in the house.
When isolated from the house and going mobile. No ground earth connection. Use the inverter bonding if compatible. Will need to consult the manual/manufacturer about this
Panel grounding for a mobile setup would only be for lightning protection. So, if you need it then use an isolated dedicated ground rod for that. But if you're using your trailer/cart as a non separately derived system then don't earth gound it
This was a rough diagram of the system if using parts instead of an all in one. Except the cart itself with the system would move around as well, not just the solar panel trailer. As you could see - this was before considering the EG4 or any SPD.
The idea being having ground rods to use when the cart is mobile. And disconnect when the cart is parked plugged in for if it happens to need charging other than the panels. This way the frames of the array are grounded when mobile. Or grounded to thru the home system to the mainHome Ground. I was treating the trailer as more of a mobile ground mount , not a vehicle.
