Rabbit
- Nov 19, 2019
- 85
Hello!
I need to work out a way to efficiently charge one independent battery bank from another of the same voltage.
I have two 12v independent battery banks that are entirely off-grid. Both banks are lithium iron phosphate. One is fixed and immobile-- it consists of 4xLishen 280 ah, with 100 amp BMS's. The other is mounted on a custom-built cart complete with inverter, etc, for intermittent use in a cargo trailer. This mobile bank has 5 old-style (previous model) Renogy 100 ah batteries. When not in use in the trailer I store this cart at home and significantly discharge it perhaps once a week, but it's primary purpose is to service the cargo trailer. I wish to charge both of these banks from my 1200 watt 12-volt solar panel array. This was (IMO) improperly installed by someone else in that it's a single 1200 watt 12-volt string. Nor can I (for personal reasons) access this array to modify it in any way. (I have a Victron 150/100 controller that handles it well, however.) For reasons peculiar to the layout of my home, these two battery banks must routinely remain about a 30'/ten meter cable run apart. (This cannot be economically remedied.) Since I can't easily either unify the banks (due to the structure's physical layout, cable costs and routing difficulties for such large cables) or divide up the panels in such a way as to allow me to use more than one controller, what I'm trying to do is work out a means to use a DC/DC charger to charge the Renogy's from the Lishens, which have easiest access to the panel array. I've contacted both Renogy and a Victron dealer, the companies that make the best known DC/DC chargers, and both tell me that their products can't be used in any environment other than a vehicle. My next fallback would be to use a Victron 100/50 MPPT controller (that I already have on hand) to charge the cart, connected directly to the Lishen batteries. However, I'm reluctant to try this without some kind of confirmation that it's a safe and viable solution, and am concerned that I'd be attempting under some circumstances to "charge uphill". Another option I've considered is to buy a 12 volt to 24 volt converter, and then connect the MPPT controller to that. However, all of these I've seen are meant for golf carts. This isn't the sort of semi-continuous duty I have in mind. I sleep in the same building with this setup, and need _good_ gear to feel safe.
Any thoughts?
As an aside, even though it's so inefficient it hurts my eyes to look at it, as a temporary and experimental expedient I've been charging the cart using a Victron 12 volt charger plugged into an inverter connected to the Lishens. This has at least proven to my complete satisfaction that a 20-30 amp charger is all I need to supply my Renogy-cart under my own specific usage-case, and that my panels (even with this horrendous wastage) can supply all the power I personally need from both setups. So, all I have left is to find a solution to this bank-to-bank charging problem.
Thanks for all help!
Any thoughts?
