Hello All. I have a question about having multiple chassis grounding points...
The situation background:
I have converted an ambulance (Ford F-350 Super Duty chassis) into a camper. The rear box is entirely (and robustly) built with aluminum. The ambulance came with a complex 12V DC distribution circuit board/panel in the rear box with each DC circuit separately fused and relayed (fuses and relays mounted on a circuit board). Next to that existing rear DC distribution panel/circuit board is a beefy grounding block where all of the existing rear box DC circuits are connected to for their individual grounds. That grounding block is then connected with a beefy cable to the steel truck chassis underneath the rear box. The rear distribution panel is connected to the two 12V starter batteries under the hood of the vehicle via beefy DC wire as well (with a master battery disconnect switch/solenoid in between to turn off the whole system).
FYI, Ambulances out-of-the-box are meant to have their engines running (or connected to shore power) in order to run the rear box and related emergency equipment. As I am planning on boondocking/remote camping, relying on an engine running or shore power to run equipment is a definite no-can-do. So I invested heavily and have installed (more like mounted at this point) a separate power system on the opposite side of the rear box compared to the existing DC distribution panel in order to provide power to the rear box in a more autonomous fashion (no requirement to have engine running or shore power). I have installed a 700W rooftop solar array, an appropriately sized MPPT charge controller, an-in-one Inverter/Charger/Transfer Switch (i.e. a 3000W Victron MultiPlus II 2x120V) along with a Victron Lynx Distributor (a fancy efficiently-designed fused positive and negative bus bar device), and a Sterling 60A DC-DC charger, all powered by a 300Ah LiFEPO4 battery bank, and am now currently wiring it all up.
The grounding question:
I have a question about grounding to make sure I haven't done (or plan to do) anything incorrectly in that regard. As the new Victron-based system is physically located on the opposite side of the rear box compared to the pre-existing 12V DC distribution panel (and its associated grounding block mentioned in the first paragraph), I have installed its own 2/0 chassis ground wire from the negative bus bar of the Victron Lynx Distributor to that side of the truck chassis, rather than run a big ground wire from that aforementioned bus bar through/across the interior of the rear box to the drivers side in order to somehow connect to the pre-existing grounding block in the existing cabinet (also not really any room to connect to that grounding block given number of ground wires already connected to it). So now as a result there are 2 separate chassis ground wires connected to 2 separate grounding points associated to the systems in the rear box, one on the drivers side chassis frame rail and the other on the passenger side chassis frame rail. First, is that ok? Second part of the question is: If I now run the necessary DC power wire(s) across to the pre-existing DC distribution panel from the Victron Lynx distributor, effectively replacing the wire running from the truck's starter batteries so that the pre-existing rear DC circuits are powered from the LiFEPO4 battery bank instead of the starter batteries, but leave the two existing separate chassis grounds in place, is that a problem or incorrect at all?
