Multiple Grid-tied inverters
hacksics
Hi All,
My utility power is 3 phase and I have SolarEdge single phase grid-tied inverter hooked up to a single phase of the 3-phases coming from utility power. I want to increase the day power utilisation and thinking if it's possible to install 600Watt micro-inverter in to a separate phase other than the one connected to SolarEdge. Will it work?
I've added a diagram for clarity. Any input/feedback highly appreciated.
Thanks!
svetz
Works in theory! Practice? That's something else
Key Largo
Welcome to the Forums!
What you have described shouldn't work... So... guessing you don't live in the U.S. and have multiple transformers?
Can you tell us a whole lot more about the setup? For example, the voltages for L1-L2, L2-L3, L1-L3, and all of them to neutral? How is the power balanced off the transformer(s)?
crossy
Thailand, just north of Bangkok.
Assuming you are in a 3-phase, 4-wire (220V Phase-Neutral) country like we are in Thailand there's no reason why that shouldn't work.
Many here have 3 x single-phase inverters rather than a single 3-phase unit due to the commonest failure mode of the local grid being loss of one phase (or one phase going very low due to loss of a HV phase). With 3 separate inverters two of them keep operating.
hacksics
I'm in Sri Lanka. 3-phase, 4-wire (230v 50Hz Phase-Neutral). Our 3-phase voltage is 400v/410v between any live phases. Any idea why it shouldn't work?
Hedges
I See Electromagnetic Fields!
All lines 230V to neutral, independent grid-tied inverters can be put on them.
If they were one brand, suppose to talk to one controller (like our 120/240V split phase in U.S.), they might need a coupling device for data com.
But just grid tie, they won't even know about each other.
